sawblades rims
geogolf
brookville pa.
1990 L98 coupe green
back again does anyone know if the 90 corvette sawblade rims are made in 17/11 size anyone know where you can buy cloned ones any help appr.
91 was the first year of the "Saw Blade" rims. 1990 rims were a one year only stye the same as the 89's except the lug nuts where exposed instead of hidden under a plate. Of course the 17x11 of either style will fit your car.
The 1990 ZR-1 wheel is 17x11 and is the same design as the 17x9.5 1990 wheel. But the ZR-1 specific wheel had a different offset than the standard wheel so it will stick out from the rear wheelwell. The ZR-1 body was 3" wider so the wheels stayed inside the wheelwell.
Try eBay for a used pair of wheels. I don't believe that anyone makes a "clone" of the 1990 wheel design.
