A
AUSSIEVETTEMAN
Removing the hood
We had to remove the hood (7 bolts), loosen the radiator support bracket (4 bolts), loosen the shroud (two bolts) and take the top brakets off (4 bolts).
From there you can move the craddle/ radiator support forward and the shroud back towards the engine and after you have taken all the hoses and any trans lines you have, you can take the radiator out. Trust me it is easier to take the hood off and after a while you will get ggod at it.
It is also easier to remove the belt pulley on the water pump, this will make it easier to get the shroud out of the way.
2 1/2 hours to take the radiator out of our old girl!
Have fun
Tony
Brusso,brusso said:So it is so. :cry
Have fun
Tony
