MFPvette80
I've got a problem with a 350 in my 1980 vette. The engine is not original, but an LM-1 crate motor from GM... not that it should matter.
Here's the story: The vehicle ran well last season after I had adjusted the timing properly. During the winter I decided to clean-up the motor a little since the engine compartment needed some TLC. I took some digital photos of the distributor and then pulled it out. Then the intake manifold was removed, bead-blasted and painted. No other engine work was done, except for installation of headers.
When it came time to put the engine back together I consulted the photographs and replaced the distributor in the exact position it was in before the work began. New cap and wires followed. The motor fired-up just fine, and I thought all was well. When I put the timing light on, the mark was nowhere to be found. Actually it was over a hundred degrees off. The first thing I thought was that the distributor was off. After pulling it out and replacing it several times a tooth or two in either direction, nothing changed. The timing light is on number one of course.
I then pulled plug #1 and brought the piston to TDC on the compression stroke. The timing mark should have lined up, but again, no sign of it. The rotor was in the correct position however. No surprise there since the motor would run. I check the harmonic balancer to be sure a mark was there, and sure enough it was very visible... from under the vehicle.
Keep in mind that the balancer was never pulled, and no work was done on the cam or timing chain.
It makes no sense to me at all since the timing mark is basically a crankshaft position indicator, and that should not have moved.
The engine runs, but needs to be timed badly. It also starts breaking up around 4,000 RPM (the tach starts jumping all over).
Any advice would be appreciated. Thanks in advance people.
-Mike
PS- Please excuse the fact that I've posted this question on another site also (Chevy Talk). Just trying to tap into the expert advice I've seen offered from both groups.
-Mike
