Help! Seat Belt installation 1964 Coupe
Jack64
Massachusetts
1964 coupe
Installing new seat belts in my 64 Coupe.
3 of the 4 mounting bolts (retro from Paagon) tightened nicely.
The 4th bolt will NOT tighten
It is located on the Driver's side, outboard.
Threads are visible in the hole where the bolt installs, but it is as though the bolt is too small.
Yes, I tried the other three bolts and had the same results.
Help!
Thank You
Jack64
It could be that the bolt stripped out once and was tapped out to the next bigger size. I'd check it with a tap to see what size fits it. You might be able to repair it with a Heli Coil.
Tom
I suggest you just use a larger bolt that fits the odd thread you have.
I think it would be unsafe to use a helicoil in this application!
Sent from my iPad using Tapatalk
Tom,
As usual, thanks for your advice.
Will try your recommendation with the tap
Thank You
Jack64
