SEAT BELT INTERLOCK..esp 1974's
  • Thread starter Thread starter Robin7TFour
R
Robin7TFour
GREETINGS, my 74 came with the seat-belt system that disable the starter unless the seat belt was latched. my question is: is it possible to remove the reset box in the engine compartment? mine is just above the a/c heater box.
i've had some intermitten starting problems and think this might be the problem ....
thank you
ROBIN
MATT, THANK YOU VERY MUCH. that was just the info i needed. i previously checked the neutral switch and related wiring. the by-pass was the only thing that was left.
the pictures are excellent. i will take care of that at work tomorrow.
mertle beach hmmmm. spring time , harleys ,putt-putt golf. i see a plan forming.
thanks again
your friend
robin
MATT, good call on the by-pass of the seat belt interlock. since i did the mods haven't had any starting problems. thank you again!!
ROBIN
