Roadster Guy
- Joined
- Oct 17, 2004
- Messages
- 261
- Location
- Rolling Hills NE of Toronto
- Corvette
- 1996 Roadster CE/LT4/F45
This seems minor, but it has me a little puzzled.
Last year when I put my Vette into storage in my outbuilding, about two weeks later when it got really cold in December, I found a very small amount of coolant pooled underneath the rad. I could not figure out where it was comming from and I looked everywhere, but I thought it was a rad leak. As the roads were dry and salt free (no snow that December), I drove her over to the nearby GM Corvette Dealer (never been there before). Turned out it was just the top driver side hose clamp being loose right at the rad connection...and so they replaced the clamp and did a pressure check and everything was fine and that was that..and didn't even need to add coolant...no big deal, very small charge and I was relieved.
I checked under the car all spring, summer and fall and never a drip and coolant level unchanged.
So, a few days ago, which would be about 2 and a 1/2 months into storage I see a small amount of coolant pooled on the floor. I check the whole rad and hose areas and then the top driver side hose and just underneath the hose at the rad connection is some coolant. And the clamp is a little loose, so I give the screw a turn till it's snug and I guess that is that. The coolant appears to have stopped leaking.
So, same hose and clamp two years in a row. The hose is only a couple years old and the clamp is now new. So I am wondering, is it one of the following that caused this:
clamp loosened up with vibration during the driving season?
the sudden arrival of very cold temperature caused something to contract?
there could be grit between the hose and the rad pipe it attaches to?
the clamp was loose last year and was still not tightened enough by GM?
the Vette is jealous and acting up because I only got tickets to see Tom Petty in June for my daughter and I?
Anyone encountered this kind of thing before?
RG
RG
