UncleBuck
Ok here's what's goin' on: I had my 04 convertible detailed yesterday, when I picked it up the detail guy made a weird comment. He said the vette wouldn't start so he had to turn off the radio and then it was ok. I got into the car and it started fine. I pulled out of his place and noticed my "Security" light on the dash was still on. Got home did some research, tested the TDS and it worked fine. So I figured it "self-healed" (LOL). Went out this a.m. and car would not start with key #1, it did start with key#2. Pulled the following codes:
10-PCM - Powertrain Control Module
P1631 Theft Deterrent System Password Incorrect
40-BCM -Body Control Module
B2721 PASS-Key Detection Circuit
A1-RDCM - Right Door Control Module
B2263 Horizontal Position Sensor Fit
B2265 Horizontal Position Sensor Fault
Reset those and attempted to start car with key#1 again. It worked fine!!!!!! I should mention that as part of the detail the engine compartment was washed. Now it seems the car works okay, but there is that little doubt that is creeping in about taking on a trip and then it won't start. Any ideas??
