WayneLBurnham
- Joined
- Dec 30, 2002
- Messages
- 304
- Location
- Dallas County, Texas
- Corvette
- '75 Modified Red Ragtop: "LEFTLN"
From the following symptoms, take a guess at what I find wrong tomorrow:
It didn't take long to find the weird scary mystery noises that were getting worse and worse in the engine - so bad I had it towed home from work to not damage anything worse.
Tomorrow I tear off the intake and the head on the driver side - and, if necessary, the oil pan to get to any involved rods and pistons out.
Engine is a high end but mild SBC - 400 0.060" over (413). All forged, hyd roller. 10.6 CR. 460/500 hp/tq. Edelbrock and Comp Cams throughout. Highest level fasteners available (AARP L19) were used and everything possible is a stud. 4 bolt splayed main with billet caps. Heads extremely ported - flowing nearly 300 cfm intake and nearly 200 exhaust. One piece manleys of standard 202/160's. Custom pistons from Diamond. Ignition is MSD ProBillet with 6AL box. 750 dp Holley.
This is the albatross engine that was "professionally" machined and built and first ran at the turn of the year. Less than 5K miles, rev lmtr at 6800 and never brought to that. Has had three major breakdowns - a destroyed incorrect bronze distrib gear and two seperate head gasket failures (one from that first event), both times a few valves had to be hand lapped to reseat them due to small leaks and the blown head (don't know if the same one) was bench flow tested for leaks and such and milled 0.001-0.002 to make smooth. One of these heads blew up on a earlier motor and had a chamber welded and recreated (this was subbed out by the engine builder and was really an amazing job.) You really could not tell which was which.
I had a minimal and non-specific miss. Despite the best cooling system possible, it ran warm, but not uncontrolled. Oil pressure same as always - lower than normal due to remote oil filter and cooler -15 at fast idle, 40 at cruise, 45 max, 5-10 at 5-600rpm (no lifter noise produced). Vacuum steady and high - 16-18 normal, high at 21, low at 9-10. Both a/f gauges run super lean, but I had ascribed that to the oil and tranny leaks only recently cured - which always play havoc with them. Horrible noise that went up with RPM but not temperature, runtime or hot the engine was - something in between the deep sound of a rod knocking and that of loose lifters. No back fires or afterfires at all. Started easily. When the plugs came off, they were fine, slightly sooty but not caked with deposits - and uniform. I reset the guideplates which were making a number of the rockers be off canter quite a bit and it didn't affect anything. Oh - all the rockers rise and fall as much as each other - which is 0.560" on mine, and of course I reset all the lifters. None of the p-rods were bent or worn, nor was anything wrong with the nearly new promag roller rockers. All the valve springs look normal and even as do the ends of the valve stems and keepers. There are no marks on the stud girdles or anything else.
Well, I was going to rip off the intake to get at the lifters and then proceed to tear off the timing chain cover if I found nothing there. I decided to pull a compression test first. Had to do it cold. They all ranged 182-194 (only two over 190) - that is all, except #3, which was - ZERO. NO pressure. I thought the gauge was broken so I put my finger down there - nope, only a slight vacuum feeling as it turned over but NO air pushed out - NONE. The vacuum "pulse" was also much weaker than all those on that side.
That's the info you get - all we have so far! Take your best guess at holed piston, broken valve, broken valve seat, blown head gasket, bent rod, holed chamber. Be specific - even WHICH valve, which parts - hell, even WHERE on the piston the hole is if that's yor guess! I won't read the replies to this until tomorrow night, by which time I'll have the offending parts plucked out and will name the winner(s)!
