Curious George
- Joined
- Oct 31, 2008
- Messages
- 290
- Location
- Orlando, Florida
- Corvette
- '92 Red Convertible / '99 Red Convertible
Since I bought my '99 C5 (in August late '07) it has had a "chatter" from the serpentine belt / tensioner. Here is the scenario: Start car (A4), when you put it in Drive, you hear the belt / tensioner chatter for a moment, then it goes away. If you happen to turn the steering wheel left or right (immediately after putting the car in Drive), the noise is slightly worse, then goes away. With the hood up, and car running, you can actually see the serpentine belt and tensioner chattering under the above conditions. After the car warms up to operating temp., it is not so bad, but it is still noticeable.
I replaced the tensioner pulley and tensioner itself, no change. New serpentine belt, no change. New A/C belt, no change. A/C tensioner / pulley appear to be OK. The harmonic balancer separated awhile back and was replaced, but the chatter still prevails. Power steering pump appears to be OK, no leaks, etc.
Any ideas what could be causing this because it is driving me CRAZY! I've been driving my C4 more since I cannot stand it... poor old girl.
CG
CG
