69/99
- Joined
- Apr 18, 2002
- Messages
- 23
- Location
- Bridgewater, NJ, USA
- Corvette
- 1969 coupe, 1999 convertible, 2018 Z06
I recently bought a 99 C5 convertable with 9700 miles. The other day after taking it for a drive I put it in the garage and as I was putting the cover on it the lights and door locks began to erratically flash and lock (I had the passive feature enabled). To stop this from happening I pressed the key fob unlock button and it stopped but the key fob passive feature no longer was working. I then entered the car and started it up to check DIC options. The passive unlock feature could not be changed with the reset button and the DIC display had the following messages: Service Tire Monitoring System, Check Tire Pressure, Service Vehicle Soon. When I checked the tire pressure option, all four tires had no reading dislayed, yet the tires are all properly inflated. I took the car for a ride to see if the tire pressure sensors would reset, but did not. Has anyone experienced this same problem before? If so please advise. Thanks.
