cyclist7531
New member
The car is a 1991.
Here is what happens:
1. Turn ignition key to on and ABS light comes on then goes off as it should
2. Start car and I hear the ABS pump do its whirring noise thing and then the ABS activated light come on then goes off as it should.
3. Start driving and then the Service ABS light comes on. This light only comes on once you start moving, but stays on.
This car has aftermarket 12" cross-drilled rotors and 17x11 AFS wheels in the back and 17x9.5 in the front.
Tire sizes are:
Rear - P31535ZR17
Front - P27540ZR17
I came across this when I noticed no ABS light at all, did some digging (I know I should have caught this but I didn't -as I beat myself up) and found that one of the ABS harnesses was upplugged under the rear storage compartment near the ABS unit. Once I plugged in the harness is when this was discovered.
Since it only comes on once I start moving I'm wondering if it could be a wheel speed sensor or is the ABS unit getting confused because of the tire size?
I checked the fluid in the reservoirs, the one closest to the master cylinder is at max and the other one is about a 1/4" from max.
Thanks,
mark
Tire sizes are:
Rear - P31535ZR17
Front - P27540ZR17
Thanks,
mark
