S
Skylark
My Service ABS, Service Traction Control, Service Active Handling warning came on and won't reset by turning the ignition off then back on. Inquiring the DIC came up with 28TCS Code C1214. It says "Sol Valve Relay Control or Coil CKT Open". I found the code in the Knowledge Base but it doesn't indicate a service bulletin or how to fix it. This code was both in current and history but, the previous owner says he has never seen a warning of any kind. He was the second owner and had the car since 8K miles.
Does this ring a bell with anyone and, if so, what's the fix and how expensive is it?
Many Thanks
Les ;help
Many Thanks
Les ;help
