Service Traction Control warning
Binghamton, NY
1981Dark Blue Metallic & 2004 conv. magnetic red
This came up on the warning, kicks speed control out yet it drives fine. Before I spend bucks getting this into the local Chevy dealership any ideas if others have same concern?
Chuck
Codes would nice!:thumb
Don't clear them yet!~!!
How to Pull Codes:C5
1. Turn your key to the "ON" position, but do not start the engine.
2. Clear any present messages by pressing the RESET button.
3. Hold the OPTIONS button down, and press the FUEL button 4 times. (This will get you into the "codes" section of the DIC.
4. The computer will automatically display all the codes your car has created. It will cycle through each code every 3 seconds. (Have a pen and paper handy to write down the codes)
Note: Any code that ends in an "H" is a history code (something that has occurred in the past, but is not reporting as an error currently.)
5. Once the computer has finished going through all of its codes, press RESET to enter Manual Configuration mode. It should start with a module and show "NO CODES" or "# Codes."
6. To optionally reset codes once in manual mode, press and hold RESET until is displays "NO CODES."
7. Press OPTIONS to go into the next module (ie, from PCM, or Powertrain Control Module, to TCS, or Traction Control System.)
8. Repeat Step 6 until you have reset all the codes in all the computer modules.
Note: Only reset the codes if you want to- it is not necessary to reset them every time you pull the codes.
9. When finished, simply take your key out of the ignition.
Thank you for the information and I will try it. Any idea what might have caused this to appear?
Chuck
Chuck
No one can offer a useful answer until you get any fault codes which are set in the brake and traction control module.
Get the codes then post them. Then, we can get down to business.
