- Moderator
- #1
vetteboy86
Well I took for granted that the service engine soon light coming on was the same old EGR code again. Well tonight the car started to idle a bit rough, idle surging mainly. I also noticed it running a little hot.
Well I get home, and pull the codes. I get a 24, a 42, and a 44. Okay when everything went back in , and out on a test drive the speedo didn't work, he found that problem and corrected it. I believe that is where the 24 or Vehicle speed sensor is coming from. Obviously he adjusted the timing after the car was running and had the EST wire off. So I believe this is the cause for the 42 error code, or Electronic spark timiing code.
However why I am getting a 44, Lean exhaust, is beyond me. I guess when I take it to him tomorrow, we can hook it up on the scanner. Is the oxygen sensor responsible for monitoring this? I would imagine. Well either one of three things is making it run hot.
1. The coolant level is not full, did momentarily have a low coolant light.
2. The water pump I bought is not keeping up with the increased heat due to the engine mods?
3. The car is running lean, and getting hotter.
What do you all think?
