jimmers
When you go to set the TPS voltage i am told to loosen the 2 torx bolts then rotate the TPS to adjust the voltage. How exactly do you rotate it? Mine doesnt really turn at all. Am i missing somthing?
geekinavette said:Ken....I think you meant V (Volts), not mV (milli-Volts).
Bill
What exactly does this accomplish?jimmers said:When you go to set the TPS voltage i am told to loosen the 2 torx bolts then rotate the TPS to adjust the voltage. How exactly do you rotate it? Mine doesnt really turn at all. Am i missing somthing?
