craig32
Can someone remind me of the procedure for setting solid lifters? I think it is - #1 @ TDC, set #1 and #6, rotate 90 deg., set #8 and #5, rotate 90 deg., set #4 and #7, rotate 90 deg., set # 3 and #2? .020 with feeler gague between the rocker arm and valve stem? Did I remember all that right? It's been forever, just want to make sure - Thanks!
Craig
Craig
