Shocked and Loose
  • Thread starter Thread starter jasbogart
J
jasbogart
I recently purchased my 94 with 87K miles. The front end feels a little "loose" and I was hoping to get some feedback on some front end issues.
First I plan on replacing the shocks. I would like to upgrade the fronts with the Z51 set from Bilstein, I assume they will fit into my non-Z51 shocks place. Does anyone know if I am correct? (there is NO FX-3 adjustable option)
Secondly, I know Ecklers sells a complete front end rebuild kit, but what other parts do I need to concentrate on to get that new car tightness back in my front end?
Thanks, and by the way, I've been a member for about a month now, and this is one of the best on line communities I've ever participated in....kudos!
Jason :J
Jason...you may want to look here http://www.bilstein.com/ then click on the "Links" icon...It will give you other sites to see about applications.
You may also want to check http://www.p-s-t.com/ they have a complete front end set including tie-rod ends, ball joints and poly bushings at a resonable price.
Does anyone have any experience with the Edelbrock shocks?
I know they are pricey......I mean...hella expensive, but they seem pretty nice.
Jason
I just put shocks on my base suspension 94 with 80K on the clock. Here's my experience for what it's worth.
I felt I needed shocks based on the mileage and what to me, felt like a harsh ride. I ran the question by the group here and all agreed the the shocks should be pretty well gone.
I too looked at Edelbrocks and got good feedback from the group but when the best price I could find was around $460 for the set I opted out. My second choice were the the standard replacement Bilsteins. I had a problem installing them ( a defective lower bracket on 1 front shock) and because there were apparently no replacements in the US, the dealer (The Last Detail) offered to replace them with a Z51 spec set. They assured me I would like the results and I did. Since I'm new to the car I don't know what it's supposed to feel like but the difference was amazing. I felt it when I backed down the driveway after I finished the job. The car is much more supple and eats up bumps that used make the car snap a creak (me too) . That side step hop on bumpy curves is gone too.
Insatllation wasn't too bad once you figured out what tools to use and what extraction techniques were needed. I had a few hitches but it went well and was well worth the effort.
Hope this helps.
Pete
