shocks or something else?
  • Thread starter Thread starter white97
W
white97
Hello. I need a little help. When I go over a dip in the road the car squeaks. It doesn't do it if I go over railroad tracks, etc. It just seems to happen when I am going over a dip. It sounds like the whole car is squeaking. I took a guy from the Corvette Dallas shop, and of course it didn't do it. Any ideas.
Thanks,
Tracy
Moving from the Corvette Stables Forum .....to the C5 Tech forum....
Does anyone have any idea what this problem could be? I think maybe new shocks or struts. Just a chick who needs a little help with this one. I had the rear sway bars replaced. I am not extremely mechanically inclined. Any help would really be appreciated.
Thanks,
Tracy
I will give my O2 , I believe it is the bushings holding your springs it place , you only have 2 , one rear and front . You could jack up the car and check for cracks , try spraying graphite between the spring and bushing ,WD40 will eat up the rubber. You could replace the bushings , if you go with polygraphite bushings you could introduce a sqeeking promblems and noisier ride , since they are harder than the stock rubber . I would do new shocks at the same time .
Thanks ,
Joe
Joe,
Thank You. I will check the bushings. Your 02 has reallly helped.
Tracy
