bumblbe
Can anyone recommend a good short throw shifter for a 6-spd C5? I tried out a C5 with the Hurst version, but it rattled. What's with that? The factory shift throw on my 2004 seems so long. I appreciate your comments.
A solution I have seen to the rattle problem is installing half a tennis ball over the bottom part of the shift handle before you put the boot back on.bumblbe said:I tried out a C5 with the Hurst version, but it rattled. What's with that?
MsSchroder said:Question: In general, is there a trade-off between a shorter throw and ease of shifting? What I mean is, if I get any shorter throw shifter, will I have to exert more effort to shift? And is the shortness of the throw inversely proportional to the effort required? (sorry if this is a dumb question).
(I knew I shouldn't have dropped that Physics class)
That's true.MsSchroder said:Question: In general, is there a trade-off between a shorter throw and ease of shifting? What I mean is, if I get any shorter throw shifter, will I have to exert more effort to shift? And is the shortness of the throw inversely proportional to the effort required? (sorry if this is a dumb question).
I agree. I have the Hurst shifter in my 03 and do not have any noise. I love it. There are ways to overcome the rattling. The first is to take out the stops in the shifter. They are not needed since the C5 tranny has built in stops. This seems to be the source of rattles for most folks I have heard from. Another is to use a heavier shift knob which will dampen any noise and vibration. The springs included with the Hurst are used for the side to side motion only, not up and down through the gears. The shifts take a bit more effort but are shorter and crisper than stock. There are always trade-offs. If you get the Hurst, go with the lightest springs. It will seem very loose until it is installed, then the side to side effort is much greater. Have Fun.P-ColaVette said:Hi Tammy
The best way to explain the "short throw" shifter is, it shorten's the distance the shifter must move to engage each gear. The Hurst shifter is adjustable in the "effort" aspect by certain springs, which there are 3 different levels of springs included with each shifter. I have a Hurst shortie in my car, and I have had NO noise issues what-so-ever ! Hope this gives you some understanding,...
Steve.
