Side Window Adjustments
Andover, MA USA
1986 "Bright Red" Coupe
Does anyone know how to adjust the up position of the door windows. I can find an adjustment for the rear of the glass, slotted holes that mount the power lift mechanism to the door, but can't seem to find how to adjust the closed height at the front of the door. Factory manual just skips over these details.
Rabbit
sonoma ca usa
2004 C5 coupe, MSGM & 2014 Cad SRX Crystal red
I don't know if this applies to 88's. This is for a 95.
The adjustment you are looking for maay is located below the anti-rattle pad at the front of the window.
C
c4ever
85 adjustment points as follows:
Glass guide stops,anti-rattle cushions,regulator bolts top of door and saddle to glass.
Hope it helps.
Carlo
C
c4ever
You can pick them up at any of the suppliers. CC, Ecklers, etc.
Carlo
Andover, MA USA
Rabbit I don't know if this applies to 88's. This is for a 95.
Thanks Rabbit, I found the adjustment, just below and to the front of the anti-rattle pad.
