MaineShark
- Joined
- Sep 21, 2002
- Messages
- 1,326
- Location
- Rockingham County, NH
- Corvette
- 1979 L82, 1987 Buick Grand National
Six-speed cluthless manual
In trying to figure out my transmission, I've been getting pretty far into the "what if" side of things, and I'm curious about the potential interest in something that I have been working on:
Based on an automatic transmission and a external overdrive unit, it would give you six speeds and manual shifting. There would be no clutch to work (my big reason for wanting it, since my knee injury makes a clutch an iffy proposition), or to wear out. Other than the lack of a clutch, it should be functionally extremely similar to having a six-speed manual. You'd have an H-pattern shifter, just like with a manual. The only real significant differences that I can think of, is that neutral would be its own position (not the center bar), and you'd have a "park" position, as well, instead of leaving it in gear when parked.
I haven't really looked into the details of marketing it too closely, but here's my basic idea:
Since transmissions are heavy and expensive to ship, the system would be made up as a kit that you could install into a transmission, yourself, or have installed by a mechanic. It would include a replacement shifter assembly, modification parts that would need to be installed in the transmission, and the external overdrive and its wiring harness. You'd also need to have your driveshaft shortened to account for the length of the overdrive.
Obviously, a lot or the potential for interest depends on price, and I can't say that it would likely be an inexpensive conversion, but it would be nearly bulletproof, and offer six speeds instead of the typical four that overdrive automatics have.
So, I'm curious about how much potential interest people think there is. I'm seriously interested in doing this, myself, but I will approach the design different if I am designing it for potential production.
Joe
Joe
