69MyWay
Okay, I am going to have to yank the trans out of the 69 real soon, if not this afternoon. It appears to me that I don't have enough clearance between the hydraulic release bearing and the clutch pressure plate fingers. Although it appeared to measure out fine on the work bench, I seem to be making contact between the two which has been causing the clutch to slip in high gear when I nail it. I think I am just ever so slightly making enough contact to do this. The kit comes with shims to adjust as needed.
There are tons of problems with taking out just the trans. The Lakewood bellhousing is very tight, not to mention the hydraulic line does not slip in and out easy. Long story short, I may have to lift the engine forward, or out to do this...ad Please remind me, this is all fun and games, and my hobby.......
So far Nikki and I both agree that the four speed muncie stinks the big one. I am sucking huge amounts of fuel and running 3,000 RPM just to keep up on the highway. I swear to you, this RAT motor in the car will take off in fourth gear. Most of the time I have been going 1 to 4 because 2,3 are a waste of time. A few times I have taken off in 4!!!! I keep trying to move it up a gear being use to the 90 six speed, the 00 six speed, and even my last two GEO metro five speeds.
Here are my options.
1. Richmond Six
2. ZF from a 89-96 Vette
3. F body six speed 93-02
4. Tremic (sp?) six speed
5. F body five speed 82-92
6. Overdrive unit mated to the Muncie (like Redmist did)
Of the options, the Richmond should bolt right to my Lakewood shield, has been done before (I think Merlin/Project Insane is running this one), and maybe even use my current hydraulics and at least my pressure plate. - most expensive though.
The other options require much more guess work and mods (which I enjoy), but I would loose the Lakewood shield on the others and my hydraulics. The ZF is a noisy trans. I believe this was the trans of choice with Hibs Big Block from Hell series.
The other question is, could I pull this off before Sharkfest, or should I just fix my current problem and put this on the back burner? Could I sell my Muncie and related hardware for enough to help offset the cost? Could I donate enough blood plasma over the next couple of months to make up the difference
BTW, expressing myself like this is an awesome way to make decisions. Sometimes just writing it out and reading it over and over helps clear my mind.
1. Richmond Six
