marckschwartz said:
I just bought a new 2002 six speed coupe. When the clutch is out there is a rattle that is louder when the car is warmed up. It disappears when I engage the clutch. It has been in three times and the answer is absurd. I am being told that some fifty other owners across the country have complained and it is an engineering problem with no fix. Not every six speed has this problem!!!
You don't explicitly state this, but I am assuming you are hearing this noise when the transmission is in neutral and the clutch is engaged (i.e., the pedal is out). If the noise disappears once you put the transmission into first gear and engage (i.e., release) the clutch then the noise you are hearing is the transmission input shaft. Disengaging the clutch (depressing the clutch pedal) in neutral stops the input shaft from spinning so the noise disappears.
Stan (vettepilot) correctly stated that this noise will get louder as the transmission lubricant warms up and thins out.
My '92 with the ZF 6-speed was so noisy I swore something was wrong. I took it back to the dealer and their tranmission mechanic told me I was lucky, I had a quiet one. He wasn't kidding. I went autocrossing and sat inside other idling C4s with the ZF 6-speed. They were much louder than mine. I put 65,000 miles on that car, a lot of those in stop and go traffic on the 405 freeway in Southern California. I also drove the car in many autocross (Solo II) events. It never caused me any problems other than the coffee-grinder noises when the car was in neutral with the clutch out (i.e., disengaged).
For what it's worth, my Z06 with the M12 transmission makes a faint noise in neutral with the clutch out. However it's nothing like the noise in the ZF 6-speed. The noise disappears when I disengage the clutch and the transmission makes no noise when the car is in motion.
The ZF (Zendhausenfabrik, made in Germany) 6-speed was developed to handle the torque of the LT5 engine so the gears were relatively rough-cut. This is what accounted for the noise in those transmissions.
My advice is to sit in another car (actually as many as possible, go to an autocross) with the M6 transmission and get a sense for just how loud yours is in comparison.
Sometimes the dealer's mechanics know what they're talking about. Sometimes.
