bucket
i noticed that when i pull back on the top of my steering wneel that there is a significant amount:W of give to it...
whats up with that.?
Probly the 3 torx screws in the column under the turn sig switch,Or the tilt pins are loose!Happens allot on C4's,seems likes everybody like to pull their self out by the steering wheel!!:L
Naw,it ain't that bad!!You can set in the drivers seat to do it!!ok then..ill take a few vicoden and crawl under there and have at it...
:BOW
Naw,it ain't that bad!!You can set in the drivers seat to do it!!Be sure to disconnect the positive battery cable and ground it,I'd hate to see you eat a Air Bag!!
PS Be ex specially careful with the clock spring under the steering wheel,It's the connecting circuit for the air bag,they won't take much abuse and there Expensive!!
