formul8
My '94 had a new opti and Autolite plugs installed right before I bought it. The injectors were checked for pulsing and they all came out OK.
I had to replace a bunch of parts because the car sat for a long time. I installed new AC DELCO premium wires.
It was missing before I even changed the wires. It is a slight "pfft...pfft...pfft" from the pass side tailpipe. There also seems to be an exhaust leak from the drivers side under the heat shield right after the converter.
I pulled plugs #1, 3, and 5 after driving the car for 100 miles or so. Plug #1 was totally clean and looked like it was firing, but almost no build up. It does not smell like raw fuel.
#3 & 7 had normal signs of firing with some carbon buildup.
Could the #1 plug being totally clean be the miss fire? The only thingI can think of is the injector is plugged up and not squirting enough fuel.
