pilot bushing and...
Billy:
Mike's right, and a kit'll help ensure you'll have the right parts.
Are you gonna do the work? If you are, you might take your stuff to parts store and match 'em up. You'll also need a clutch pilot tool to center the clutch disc on the flywheel... tool is available locally and cheaply.
The transmission input shaft should have either 10 or 26 splines... verify your new clutch disc has the corresponding number.
A kit should contain a clutch friction disc, a pressure plate and a throwout bearing. BUT, one thing that I've never seen in a kit is a pilot bushing or pilot bearing. This is a small, rather inexpensive item that fits into rear of crankshaft... this pilot bushing supports the forward-most tip of transmission input shaft. They do wear out but are often overlooked when doing a clutch R&R. While trans is out, make sure your's gets a new one... available locally.
Also, be prepared to have your flywheel resurfaced at auto machine shop. It is possible the clutch disc's rivits might have scored the flywheel face and / or the face may've become overheated evidenced by blue spots on flywheel face and / or you may find galling or micro-cracks (visible w/naked eye) in swept area of flywheel face. All three conditions are common finds. Resurfacing flywheel is not so expensive... don't scrimp on this either.
Also, check the teeth on the flywheel's starter ring gear... if they're badly worn, now's the time to fix... on some flywheels the ring gear can be simply "flipped" while others require new ring gear. Neither solution is terribly expensive.
While trans is out for clutch R&R, that'll be good time to replace front and rear transmission seals... also available locally & inexpensively.
Also, check the clutch release fork for undue wear/cracks. Hope this helps. JACK:gap
