- Joined
- Jun 5, 2001
- Messages
- 2,231
- Location
- Northern Virginia
- Corvette
- 71 Conv. (Sold) / 98 Pewter Coupe (Sold)
For level set, it's a 98 A4 with 68K on it. The problem occurs more when the fluid is still pretty cold, under 100 degrees, but still occurs with less severity at normal operating temps. I had the filter replaced and a flush performed with Mobil1 trans fluid but the problem persists.
After the car shifts into fourth and I hit cruising speed it feels as though it drops in and out of lockup for a couple of seconds then it seems to fins its place and is fine. The times when it doesn't do the in/out thing, it just feels like it slams into lockup instead of the smooth operation it should be.
Any ideas what is causing this? I have pulled codes and nothing powertrain related shows up at all. Could low fluid level cause this? If so, how do I actually check the level? I know I have to remove the plug with the car running, but how do I know what the proper fill level is?;help
Thanks,
Thanks,
