E
eagle1_77
SBC 350 with new forged pistons
Hello
I have just to rebuild my small block for my corvette.
Here are the parts i have used to rebuild it.
Block 3970010 350ci
original connecting rods
New piston TRW-L2252AF40 from summit racing
original heads with volume chamber 76cc
Compression ratio 10.23:1
When i make a cold start, the engine crank without problems.
But when then engine is hot. It's very hard to crank it.
The gear of the starter is going up to the flying wheel but the engine move very slowly. But it's start ! "As a battery is out of order".
If you know where the problem is, i will be very happy.
The first idea is that the clearance between the piston and bore is to low
and when the engine is warming, the diameter of the piston increase.
And Happy new year from France !!
Hello
Block 3970010 350ci
