Thank you for the response... The noise is definitely from the Smog Pump area, and it is not a squeaking or purring noise typical of a normal pump if new. The tensioner was just replaced last week, the alternator is quiet, and the AC Compressor is not too old either. This is a new smog pump, but the noise/vibration is not a typical "new pump" noise. The noise is not there when the motor is above high idle (while driving), but when slowing down (about to stop) there is an intense vibration noise just before it drops to an idle. This is louder and vibrates more when the AC is on, but I think it is just the added strain on the belt drive system. With the hood open I can hear/feel the pump making this loud "brrrrr" vibration/noise. If I rev the motor it quiets down till I let off the throttle... when it drops almost to an idle and It will make the vibration/noise (and while it is idling).
Question: Would anything with the Smog Pump air connection cause this problem? How is this checked out if so.
Any help would be greatly appreciated, I thought a tensioner pulley would have fixed it, then went for the bigger $$ item and replaced the Smog Pump - but nothing changed.
