krscholz
:L Hello friends, if you track my threads from several months ago I discussed taking off the my smog pump and replacing the Cat with 2 1/4" dual exhaust just like the good ole days. Here it is nearly a year later and I can say that my car is running great and the Magnaflows running out of the rear give the car a nice hum. You don't need to do any modifications to the timing or carburetor as I heard by taking off the smog pump. Just install the dual exhaust and listen to the roar. Although, I haven't measured but I believe the horsepower seems better. If you’re worried about smog testing your car, check first with your state to see if you’re exempt due to the age of your car. Corevtter Central had the best deal I found.
