dknight
Weird thing happened to me yesterday. Went to replace the smog pump because the bearing were making some nose. The replacement pump from napa had 2 problems...the pulley bolts supplied were not correct size for the pulley...way to small and the small support brace on the back side...the bolts from the old pump were to big for the threads on the new pump. The other main mount bolts (2) were perfect along with the housing the hose attached to. Have you seen this before? I will be taking this one back... Thanks
