So EAGLE!!!! It's in!!!
vigman
Motor head!!!!
Valencia, CA,USA
So I scored a Hypertech Thermomaster chip from Eagle for a SONG!
And he shipped it to me FIRST without payment.. ( trusting soul )
It just got stuffed in! With the Reman ECM from Mid America.
( 20 minutes.. piece of cake )
So here's the deal
Well I didn't see God from the blackout from pulling to many G's
But
About a 5-7% increase in hoserpower.
Idle's the SAME ( smooth ).
Fan come's on @ 180 ( Main ).
Shift's a tad firmer.
Ping's JUST a touch ... gotta back my timing off 2 deg ( so 4 deg BTDC )
So TADA!
Now the science projects of the week
This did NOT fix my .......
No main fan on A/C request issue.
( Back to the drawing board on that one)
AND
I've gotta figgure out what the diff is between this 89 Auto chip ( NON CA )
Part # 128982 and the correct 88 Auto chip
Part # 158331...
And it starts SMOOTH... before it would crank 10 times before she would light.. now it seems like 3-4...
Last week, I disconnected my Cold start valve @ the sensor.
When this was hooked up It took 15-20 cranks before she would light and would BELCH a waft of premimum fumes out the back... ( Ah the joys of remote start ).
SO THANKS EAGLE...... You DA MAN!
( I dropped the check in the mail this morning)
Vig!
vigman
Motor head!!!!
Valencia, CA,USA
No really
I put the check in the mail THIS MORNING!
And my Corvette IS PAID FOR!
Vig!
Baldie88
Waterloo, IL USA
2016 triple black vert.
For your no main fan when the AC is turned on you might want to check the high pressure switch. It's the smaller of the 2 switches on the line. I've also got an 88 and that's what fixed mine. There's a shrader valve under the switch so you don't lose the charge. Only problem was keeping the o-ring on when seating the switch because the small amount of freon that leaked putting on the switch kept pushing it out of the way. Eventually got it on though. :)
Good Luck
vigman
Motor head!!!!
Valencia, CA,USA
You read my mind!
I called my local parts store... they are ordering it as we speak!
Vig!
S
Shadowing1985v
takes 10 times to start your car?
or did i read this wrong?
if so, then tune port injection should start up so easy
vigman
Motor head!!!!
Valencia, CA,USA
FYI
"before it would crank 10 times"
Clarification
10 rotations of the crank
E
Eagle85C4
I knew you would like the change....nice kick in the pants huh!
Now if I can just get rid of these hypertech stage 1's for the 85....
vigman
Motor head!!!!
Valencia, CA,USA
Another OH BY THE WAY!
So on the dash of an Auto Tach is the Odrive light..... In the begining it NEVER came on...
Guess what...now it's stuck on.....
I believe it's an indicator problem ONLY and I have been tracing this down for a while!!!!!
It's not a problem...just something different.
Vig!
