1 AND 1/8.........ten bucks at pep boys.............and about 1 and a half hours labor to change it...............GRRRRRRRRRRRRR....gotta pul the intake...if you do your own , look out for a very tiny vacumn line in the rear of the manifold............easy to miss and it must be hooked back up.
it's not really that bad....just a tad time consuming...........I pulled the wiring harness and the TB off.......it sped things up a bit.......I could probably do it in 45 minutes if I had to do it again......
