71VERT
How can you tell if you have solid lifters or hydraulic. My car has the original engine which would suggest hydraulic since its a 350/270 1971. However someone before me put on a aluminum intake from a LT-1 & The head casting numbers seem to be the same for an LT-1 and a 350small block. The LT-1 had solid lifters correct?
The reason I am asking is I have problems with the car starting and idling properly if I preload the rockers the 1/2 turn I am suppposed to. Once I set them to zero lash the car starts fine and idles good but the rockers seem a little loose. If I preload them it runs worse.
Regards
Jerry
Regards
Jerry
