Rodney Gold
- Joined
- Jul 28, 2003
- Messages
- 200
- Location
- South Africa
- Corvette
- 1986 White l98 coupe, 1995 LT1 coupe
Not too many of em here , but I have one and have decided to hop it up. It was originally a l48 and I have recently had it resprayed. Motor was completely redone and I have added Edelbrock performer RPM alloy 64cc heads , Performer RPM manifold , Comp cams 270 cam, Holley 770 street avenger , ceramic coated headers , dual 63 mm exhausts , MSD 6al, Pertronix dizzy. We have 95 octane lead replacement fuel as well as 95 octane unleaded. Im running quite a lot of advance 40 degrees total with no detonation problems. I tried 36 degrees but the car was lazier and less responsive
I have the original 15" rims with 255/60/15s out back and 235/60/15s on the front.
The car has no cat convertors , doesnt have to comply with any emmisions stuff and thus all that has veen deleted along with the Aircon. So its leeetle lighter than stock
The car goes like the clappers above 2500-3000 rpm to a true top speed of 250+ kph. Down low it wont really squeak the tyres but does launch quite well. No drama like my 454 El Camino (actually a Holden ute here in South Africa)
It ran a 13.9 on the dragstrip as is with the stock tyres.
Im getting a Saturday night special torque convertor, 1500-1800 stall and a set of 3.55:1 gears to replace the stock 3.07 (i assume my rear end is 3.07 , seen some references to 80's having a 3.55 rear end but don't thinks thats accurate)
Do you guys thing the TC and the rear end will wake things up a little at the bottom end?
I would be happy with a lowish 13 , albeit the car is not really meant for dragging , I just want a little more guts to go with its looks and to blow away eurotrash hot hatches and riceburners. Top end speed is academic , i dont like taking the car above 220kph (1.5 km/mile) as it's handling isnt that good at high speeds.
The only thing I think i might have done wrong is the cam, as it might be a little overcammed , I tried a 600 carb on the car , but it gave me no better bottom end than the 770 and was a bit strangulated up at the top.
Any comments or help appreciated.
