M
Mark Stahl
I am having someone install factory stlyle exhaust (mufflers) and spare tire tub. The problem is when the spare tire tub is in place, where the locking latch bolt goes, it seems to be about 1/2 " - 1" back from where it should be. The center holes of the tub line up correctly, but the holes which mate up to the rear frame cross member are off. Also, the tire tub seems to hang down lower than it should, i.e., entire lip hangs below bottom of rear panel. I dont know if this is a tire tub issue or a possible frame issue. Would anyone know if there are any measurements I could take or some other way of visually being able to tell where the problem lies?
Also, if the rear-most section of the frame (kick-up section) had been replaced, would there be any possible reason why anyone would shorten the frame?
