USNA1969
There's a solenoid located between the carb and the distributor. On one end of the solenoid, one vacuum line goes to the carb and another goes to the vacuum advance on the distributor. What, if anything, connects to the other end? It looks like a vacuum line should attach there, but the nipple is corroded and looks like nothing has been on it in years. The car is a little hard to start, but otherwise seems to run fine.
Also, I have two hoses coming from the area of the brake booster. The larger of the two hoses goes to the PCV valve, but I can't figure out where the other goes. It's natural tendency is to lie along the front of the carb and then turn back toward the passenger side of the carb. The second hose is about 1/2 the size of the PCV hose.
Thanks.
Thanks.
