Spark plug choices
MaineShark
Rockingham County, NH
1979 L82, 1987 Buick Grand National
I'm sure this has been discussed as much as oil preferrences, but I can't imagine a reasonable way to search for those discussions without getting a whole lot of other threads (anything where spark plugs are discussed).
So, what plugs are you running, how do you like them, and would you recommend them?
Joe
Joe,
I switched back to a standard iron AC plug after a rather lengthy discussion on the falicies of platinum. I'll be changing all my vehicles back to factory iron plugs as well.
-:argue AC-plugs??? -here's what I think of them...:puke ; -just the good'ol AUTOLIGHT 99cent-regulars will perform and last as good as any!!! The new Dodge quasi-Hemi engine has it right, two 99-cent sparkplugs per cylinder; --giving that xtra-gopower like this'en...:r :eek :eyerole :L:mad :r
Go with the factory recommendation. The gold plated platinum sugar coated wiz-bang thing-a-ma-jigger triple electrode gotta-have doesn't work any better and sometimes worse than what the factory says to use.
My .02.........:s :J :beer :w :upthumbs
I continue to use AC Delco standard plugs on both vettes. No problems here.:D
Carlo
How come there would be more power with two plugs per cylinder? I mean, isn't a spark a spark to ignite to combust? How does more spark contribute to power?
Thanks! :D
TR
I see. But there is only one spark per cylinder in the Vettes' V8s, right? Is there a mod (an easy one?) to put in another? Because that seems to sound like two only benefits.
TR
...an associated question I would have on this topic is: do split fires work "better" than just the regular old, standard plug, or should I save the few extra bucks and have a steak for lunch, instead of a burger? :)
I have not heard anything good about Splitfire plugs other than they make a lot of $ for the company. I have heard that they mess up the computer controlled firing and timing on all of the later model cars. (Those cars using sensors and computer controlled ignition).
Save your $.......:beer
I put the splitfire plugs in my '96 Ford Explorer...I noticed no performance gain or gain in fuel economy. They were a waste of $$$ IMHO.
i make spark plugs....the steel part before the ceramics are installed.most of what we do go to delphi....AC...we also make the shells for many of the NASCAR crews.....many of the men i work with used to work for champion plugs in toledo...the old timers tell of a time when champion need to seek a better plug as Bosch was gaining market.....no the champion factory is closed and Bosch is kickin the door in on the market....BUT...i still believe in and use AC.:bu
It sounds like the votes are for AC :)
Thanks for the link, DDL; I had previously been warned away from platinum, but I never really delved into the physics behind it.
Joe
