spark plugs
rodesmg
wisconsin
76 L48
getting ready for spring, just wondering what type of spark plug you use or recommend. thanks
Nothing fancy ... no exotic metals, no multiple electrodes. I personally do not care for champion brand. I like PLAIN: Bosch, Autolite, Motorcraft, ACDelco, ND (nippondenso) ... in no particular order. Get whatever range is specified by plug mfg for your year & model ... 74 on back w/ points gap plugs about 0.035" ... 75-up w/ electronic/HEI dist gap plugs about 0.045". If it's been awhile since you changed plug wires ... get new wires too ... your car will like any brand with a helical/spiral core-conductor. Accel P/N 5050 have the spiral core & are correct P/N & fit for 75-up vette w/ HEI ... nice price too. Welcome to CAC!
JACK:gap
I use Bosch Platinum. I've had a lot of luck with them on many different cars. Just be sure to get the correct heat range no matter which brand you choose.
If I don't use Bosch, I typically go with ol' faithfull ... AC/Delco. (If it's a stock motor)
right now i'm running rapidfire, just wondering if something better is out there. i know i need to replace the wires with some new ones. it is a stock 76 L48
(jack) thanks for the heads up on accel 5050, they are price right
My 350..
Uses only R44T Ac Delco spark plugs.:w
