Can't seem to find anywhere for the stick shift cars. Car & Driver has it for the z06 automatic.
Thanks if you can help.
Disregarding aerodynamics, top speed is limited by however long the engine can pull torque in the highest gear.
Judging by anything from formula cars to NASCAR, how long the road is straight is also a factor. Then there is something called pucker factor.
It is not mathematical as more factors enter into it than the gearing analysts can define.
As RPM is what counts, speed in gears is irrelevant. No engine manufacturer governs speed; they govern RPM. Using imaginary values, swapping diff gears from 3.00 to a 4.00 will not change the potential RPM in any gear but it sure will change the speed.
Correct, no different than most cars, using a 6 speed manual as the example, depending on overall ratio (product of transmission and differential gearing) 5th is usually the last power gear.
After 35 years in power train (engine, transmission, and differentials) design, one learns the numbers calculated by the analysts do not reflect the real world.
The real answer to the OP's question is if one wants to know, run it up to red line.
