billscac
96 CE LT4 Convert. 8000 Miles, manual trans and RTD. At actual 45MPH, speedo indication will jump up to 135 then down to 7 then to approximate road speed of 45 and hold there. When it does jump up to higher indicated speed the SCV Radio volume will get louder (based on the speed signal it gets from the PCM) so a signal is getting to the radio head but it is incorrect. Sometimes the indication will drop to 0 and stay there regardless of actual speed. When there is no speed reading the engine will not Idle when I come to a stop. I've replaced the VSS with a new ACDelco unit as it was the easiest (and cheapest) way to start diagnosis. New VSS... same symptoms. Took it to a local Corvette shop and After scanning with a Tech1 which showed DTC 500. The tech suggested that I unplug the RTD module to eliminate it as a possible cause. Tried that and no change in speedo function
I'm leaning towards the PCM as It decodes the VSS signal and sends it to the various other components (CCM, RTD, Cruise Control Module, and Radio head). The Radio and speedo display are both obviously getting the same signal, albeit an inaccurate one. Those signals come from the PCM which gets and decodes the signals from the VSS. I doubt that two different VSS units would both be malfunctioning the exact same way which is why I'm leaning toward the PCM as the culprit.
Any thoughts will be most appreciated.
Bill
Bill
