speedo gear...
cscarlson
SYRACUSE ,UTAH
2003 50Th Corvette
Is there some way to tell what speedo gear i have before i tear into the speedo at the transmission?
Thers like eight different teeth sizes?
I don't remember for sure - it has been a little while, but I think they are color coded. If you can unhook the speedo cable from tranny, remove the "carrier" and shine a flashlight (you might need a small mirror) to see what color it is. Then give your friendly local Chevrolet Service Department a call, and they should be able to let you know.
there are probably websites also that have the color meanings. I replaced the gear in my old 3 speed Chevy truck once to try and get the speedo right after replacing rear end gearing.
