J
Jimmy Vette
My 1980 speedometer quit working. I checked the upper cable by disconnecting it from the transducer & spun the cable. The speedo worked fine. I then disconnected the lower cable at both the transducer & the trans & it spun fine as well.
I noticed that the end of the lower cable, at the transducer has a nylon end. I am not sure what this end should look like, (it is sort of rounded off) It looks like it may be stripped. I have two questions. Is it is stripped why would this happen? Is is possible that the transducer, lower end, is somehow frozen up? Should it spin freely? Seems like it is spring loaded. I guess I am looking for some advice on what might be the problem. Thanks all.
