6
66ragtop
My 66 327 4 speed has a speedo needle bounce problem.
The needle was bouncing from 0 to 15 mph. I removed one end of the cable and lubed it with WD40. This made the bounce worse but still only to about 15mph. Next I replaced the cable with a new one. Not a AC Delco but a generic brand probably made in Tiwain or China. Before I installed the new cable I lubed it lightly with white lithium grease. Now the needle bearly bounces at low speeds but after 50mph it bounces pretty bad. It was rock steady at 55mph with the old cable.
How much and what is the best lube for a speedo cable? Is it possibly the aftermarket cable? Should I try a new AC Delco cable?
Any help would be appreciated.
