Ken said:Home.:z :cry ;help
ad
10/18/2002
G R E E T I N G S Pisces
Ideas are marvelous creatures and lately you seem to be contributing more than your share of good ones. Now it's time for the next step.
The very best of your proposals still have to be fleshed out into
working models. This might not be your strength. You hate to put your brainchild in other hands, but a different set of specialists can take it from here. Continued interference from you might diminish their effectiveness. Leave it alone for now and move on to your next important work. The spirit of past collaborations will inform each new project that you launch.
69MyWay said:Ken,
Notice the air flow meter. It made the most power the closer it got to the "magic" 14:1. It appears you are way too rich right now.
You can affect that part of the run by lowering the fuel pressure, and advancing the timing a tad.
What kind of adjustments did you make during the dyno pulls?
One final question. How warmed up was the engine before the test? If you were in cold start mode/open loop, it will never lean out, and you would be putting 100 hp on the shelf.
Curious, but I got different feedback from the guys at Morgan Motorsports. Harry Khodanian, the dyno man, said the numbers weren't bad for WOT runs, but Mike Morgan (the owner) seems to agree with you guys, he stated he thought it was a little rich.69MyWay said:Notice the air flow meter. It made the most power the closer it got to the "magic" 14:1. It appears you are way too rich right now. You can affect that part of the run by lowering the fuel pressure, and advancing the timing a tad.
None. This run was just to establish a baseline; we'll schedule more tuning when I get the exhaust done.What kind of adjustments did you make during the dyno pulls?
The engine was up to temperature (185-190) when we started the pulls, but as it got warmer the power dropped-off even more; I didn't get those charts.One final question. How warmed up was the engine before the test? If you were in cold start mode/open loop, it will never lean out, and you would be putting 100 hp on the shelf.
We did do a couple of pulls at close to seven grand, but you're right in that it (the Mini-Ram) doesn't appear to be breathing as it should.maxrevs85 said:With the miniram it should pull strong to 6g's easily.
No, we switched to speed density. Funny, but Mike Morgan is keen on using the DFI setup, but my "deep pockets" are getting quite shallow at this point and I don't think I could afford another couple of grand to throw at it. :crazyAre you still using the Maf system?
Feeling a little frustrated? No wonder -- even though you've got full command of the bow and arrows, each arrow you shoot manages to land just a little bit shy of the bull's eye. What's going on? Maybe now is the time to evaluate the tools you're working with.
Ken said:
I wish I had the room like Chris does then I'd host "Garage Get-togethers" and seminars too. Way to go Chris!!
_ken![]()
69MyWay said:
Accel does make a shorty spark plug series that might really help your situation.
-=Jeff=- said:Accel Shorty plugs are junk... Just ask vettn94
- Ceramic 2000 Spark Plug Cables
This powerful combination of Energy Core Spark Plug Cables with pure ceramic spark plug boots are unique to Jacobs Electronics, guaranteed to never burn, disintegrate, or need replacing. This is absolutely the last set you'll ever need! These ceramic boots easily handle temperatures up to 2000°F, and were designed for high-heat application where burned boots are common. Ceramic 2000 wires prevent arcing from the plug boot to the header, delivering all the spark from your distributor or coils (DIS) to the sparkplugs. Patented radio-suppression metal core with pure silicone teflon-coated jacket for increased performance and mileage. Now available with both straight and right angle ceramic boots!
- Ceramic Wire Protection Kit
For optimum security and protection, this unbelievably useful package is guaranteed to prevent the constant replacement of burned spark plug cables due to the extremes of engine heat caused by towing. Extended protection for cables where excessive engine temperatures cause cables to burn above the top of the ceramic boot as the wire exits the boot. Protects hard-to-get areas most likely to scorch. Comes with 2 Ceramic boots, (2)-7 mm, and (2)-8mm boots, 1 tube Perma-Bond, (4)-Uni-Clips, and (2)-3 in. pieces of fire sleeve. Straight boots P/N 400800 Right angle boots P/N 400801
