Tom B Hargrove
Can anyone out there tell me the Spicer part number for the u-joints on my 95 six speed, both the half shafts and the drive shaft?
Probably because that is the HD 1350 uni without the grease zerk that people use for performance apps on account of being stronger. 1310 and 1350 are two of the most common uni's used.1350 used on C3 halfshafts as well as most pickups. Any dealer should have the cross reference book to same size in any brand. I can buy them off the shelf in Australia.I got the 5-799x number of this forum, but when I went to the Spicer dealer here, they told me that is was not what their book called for in my application. Tom
Here are two more numbers that may (or may not help). My parts CD shows the following GM part numbers
halfshaft: 12522048
driveshaft: 14067678
I purchased one of the 14067678 numbers from the dealer once when I could not locate the Spicers locally, ended up not using it so it is new in the box. (BTW the GM part from the dealer does have Spicer forged into the joint. )
Sometime later I went to use it and discovered it is not the right size for the driveshaft OR the halfshaft. Not sure what the deal is there, could be an error on the parts CD or the part was boxed wrong.
My point is that if you end up buying one from the dealer take an old joint or the driveshaft with you to make sure you get the right part. I got stuck with the one I bought because so much time had elapsed before I attempted to use it, God only knows what it really fits.
This should/might ID your "GOK" u-joint! There is more comprehensive information available but here is a link to a TCI chart for "most" OE domestic u-joints complete with all dimensions:
TCI - SLIP YOKES and U-JOINTS: Applications
1984-1996 Vettes:Can anyone out there tell me the Spicer part number for the u-joints on my 95 six speed, both the half shafts and the drive shaft?
