C
CharlesBrown
Have same problem as HPG. Can hear the pump click but won't run. To access the pump I removed the seat cushion. Pump is revealed, but there's no way I can see to remove it with just the cushion off. It is held in palace with 4 small nuts. The configueration of the pumps' feet is such that a socket can not be used for their removal. Assume the seat must come out, right? How much of a problem will that be?
Thanks CB
Thanks CB
