W
Wisdom
OK, this nice car with ~5300 miles on it has intermittent brake squeaks fron the right front unit (as near as I can tell) with light or moderate pressure applied. For instance, riding the brake to go over speed bumps or pulling into the garage will get a brake squeal. It doesn't happen all the time, but it does happen often enough that it's irritating. Doesn't seem to matter if the rotor is hot or cold, but the squeal only occurs at low speeds. No pulling, just noise. Any ideas? Is this normal?
- Wisdom
- Wisdom
