I've been reading all the threads about starter heat absorption. My case is slightly different. I'm no wrench, so let me bounce it off y'all.
Got the imposter back from getting the frame straightened (long story). Took it for a drive up the highway at "speed" to test the tracking. Drove about 30 miles at 70+. Tracked nicely. Check one more problem off the list.
Put it in the garage. About 15 minutes later I decided to go for another "test" drive
Turned the key, all the lights came on, no starter noise. Nothing. Nada. Came here and did some reading. I thought, "Ah, starter heat problem." I waited 2 hours and tried again. Same problem.
Then I remembered one post where someone jumped the car and it started. So, I got out my battery charger, hooked it up, and set it to 6 amps. The battery was not drawing anything from it. However, when I turned the key it started right up! I turned it off, disconnected the charger, and tried again. Started right up! Aaarrrggghhh!
I thought I would charge the battery, but it isn't drawing any amperage from the charger (as though it is fully charged).
Any ideas? I certainly don't want to haul my battery charger around with me.
