D
Drstitt
When you turn the key and the engine starts cranking, it will not stop, even if you release the key. The engine will just continue to crank until the car finally starts. If you cannot get it started, all you can do is disconnect the battery. If you can get it started, everything works fine. The engine stops cranking, meaning the starter does not grind.
After the car is warm, you do not notice the problem because the engine fires right away.
Basically, the car will continue to crank until the engine starts.
So far, the starter has been rebuilt with a new solenoid attached. This did not fix the problem. Then, we installed a new ignition switch. (the switch mounted above the steering column down towards the firewall).
I am extremely perplexed with this situation. If anyone has any ideas, please let me know.
